SVP Technology at Fiserv; large scale system architecture/infrastructure, tech geek, reading, learning, hiking, GeoCaching, ham radio, married, kids
15847 stories
135 followers
M4 Mac Mini's Power Button Has New Bottom Location
The M4 Mac mini has an overhauled design that adds more ports in a slimmed down package, and to make everything fit, Apple needed a new place for the power button.
As it turns out, the power button for the device is located on the bottom, so as Mr. Macintosh pointed out, you'll need to tip the Mac mini up in order to turn it on (or off, using the physical button).
Apple has been criticized for questionable button and port placement with other devices such as the Magic Mouse, but accessing the power button is probably not something most people do often with a desktop machine. Macs don't often need to be turned off, and most people put them into a sleep mode rather than shutting them down on a regular basis.
The power button is located on the rear left of the ‌Mac mini‌ when looking at the front of the machine, below the three Thunderbolt ports.
Pricing on the ‌Mac mini‌ starts at $599, and it can be pre-ordered today. It will launch on Friday, November 8.
Related Roundup: Mac mini
Buyer's Guide: Mac Mini (Buy Now)
Related Forum: Mac mini
This article, "M4 Mac Mini's Power Button Has New Bottom Location" first appeared on MacRumors.com
Discuss this article in our forums
JayM
Yay! ;) I have turned my old Mac Mini off a few times with it in that back corner location.
Atlanta, GA
How Insecure Network Devices Can Expose Data Centers to Attack
Network hardware could be the hidden weak link in data center security, exposing workloads to attack. Learn why these risks matter – and how to prevent them.
JayM
Atlanta, GA
Wells
2 Comments and 3 Shares
You do have to be careful, though--sometimes, instead of water, you hit this free fuel that you can sell for a lot of money instead.
JayM
Heh.
Atlanta, GA
jepler
I mean, like a lot of things it works for awhile. But maybe that's the joke.
> Since the 1940s, pumping from the Ogallala has drawn the aquifer down by more than 300 feet (90 m) in some areas
https://en.wikipedia.org/wiki/Ogallala_Aquifer#Accelerated_decline_in_aquifer_storage
Lythimus
Yeah, it doesn't help water rights in the U.S. are so ridiculous. Capitalism only works well if things are appropriately valued. I just hope we don't stoop to geoengineering rain to fall here.
hobbified
Most places it works forever. Some places weren't meant for human habitation.
What's the fastest recorded wind speed?
Wind can whip up to surprising speeds, depending on if it's natural or human made.
JayM
Atlanta, GA
On Good Software Engineers
JayM
Atlanta, GA
Installing Cisco ISE Evaluation VM for Labbing
This post describes how to install a Cisco ISE evaluation VM for labbing. The VM will run for 90 days, providing a full feature set for up to 100 endpoints.
Start by downloading the software. I’ll be using an OVA as I’m going to run my VM on ESX:
Deploy the OVA and select Eval version:
Power on the VM. When the VM boots, the following prompt is shown:
Type setup and press enter:
You will have to configure the hostname, IP address, name server, and so on:
Press 'Ctrl-C' to abort setup
Enter hostname[]: ise01
Enter IP address []: 192.168.128.102
Enter IP netmask []: 255.255.255.0
Enter IP default gateway []: 192.168.128.1
Do you want to configure IPv6 address? Y/N [N]: N
Enter default DNS domain []: iselab.local
Enter primary nameserver []: 192.168.128.100
Add secondary nameserver? Y/N [N]: N
Enter NTP server[time.nist.gov]: ntp.netnod.se
Add another NTP server? Y/N [N]: N
Enter system timezone[UTC]: CET
Enable SSH service? Y/N [N]: Y
Enter username [admin]: admin
Enter password:
Enter password again:
Bringing up the network interface...
The installation will take some time…
When the installation has finished, you should be able to SSH to the server:
Failed to log in 0 time(s)
admin connected from 10.254.255.2 using ssh on ise01
ise01/admin#show application
<name>          <Description>
ise             Cisco Identity Services Engine
ise01/admin#show application status ise
ISE PROCESS NAME                       STATE            PROCESS ID
Database Listener                      running          10701
Database Server                        running          79 PROCESSES
Application Server                     initializing
Profiler Database                      running          14649
ISE Elasticsearch                      not running
AD Connector                           not running
M&T Session Database                   running          12559
M&T Log Processor                      not running
Certificate Authority Service          not running
EST Service                            not running
SXP Engine Service                     disabled
TC-NAC Service                         disabled
PassiveID WMI Service                  disabled
PassiveID Syslog Service               disabled
PassiveID API Service                  disabled
PassiveID Agent Service                disabled
PassiveID Endpoint Service             disabled
PassiveID SPAN Service                 disabled
DHCP Server (dhcpd)                    disabled
DNS Server (named)                     disabled
ISE Messaging Service                  initializing
ISE API Gateway Database Service       initializing
ISE API Gateway Service                not running
ISE pxGrid Direct Service              not running
ISE pxGrid Direct Pusher               not running
Segmentation Policy Service            disabled
REST Auth Service                      disabled
SSE Connector                          disabled
Hermes (pxGrid Cloud Agent)            disabled
MFA (Duo Sync Service)                 disabled
McTrust (Meraki Sync Service)          disabled
aciconn (ACI Connection Service)       disabled
ISE Prometheus Service                 not running
ISE Prometheus Exporter                not running
ISE Grafana Service                    not running
ISE MNT LogAnalytics Elasticsearch     not running
ISE Logstash Service                   not running
ISE Kibana Service                     not running
ISE Native IPSec Service               running          17681
MFC Profiler                           not running
ISE Prometheus Alertmanager Service    not running
Protocols Engine                       Disabled
The GUI should now be reachable:
That’s all for this post. In the next one we’ll generate a certificate in the CA for ISE and install it.
JayM
Atlanta, GA
